adjusting valve train? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-25-2013, 01:49 PM
i have a 68 350 olds with a non adjustable valve train well i sent my engine away its getting built to 500hp and now i have to change it to a adjusting now when i change it to adjusting thats just saying i put in bigger studs push rods and rockers that dont get held down by one bracket right? theres nothing else i should change
Old 04-25-2013, 05:59 PM
BOBCRMAN@aol.com's Avatar
You will need some way to guide the pushrod and rocker.
I once had a customer that tried just using new studs and adjustable rockers and then couldn't figure out why all the valve train noise. As the rockers wouldn't stay centered on the valve tips..
Old 04-25-2013, 06:02 PM
so valve guides will help with that right? the kit im looking at is from summit racing it comes with 3/8 studs and pushrods roller tip rockers and guide plates if i need them
Old 04-25-2013, 06:08 PM
Guide plates. Not valve guides..
Oddsmopiles is diffurnt! (Just kidding). BOB
351w valve train stewd8 Engine 32 02-26-2013 08:29 PM
Valve train questions MorrisonLC Engine 18 12-17-2008 04:03 PM
Valve Train Help!!! haley72 Engine 1 06-24-2007 01:04 PM
Tightened My Valve Train.........(One Bad Valve?) white66coupe Engine 1 08-23-2004 09:00 PM
ford hi-po valve train fordracing Engine 6 03-17-2003 07:56 PM
