Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - adjusting valves?
Old 07-22-2012, 08:21 PM
327NUT's Avatar
327NUT 327NUT is offline
Well to start with ...."the guy" who did the repairs should have adjusted the valves properly before he got it back to you. You don't send it out telling the owner that the valves need adjusting a "little more", they are either adjusted or they aren't. Since you're not mechanically inclined and therefore can screw up the valve adj. procedure I would take it back and tell the "mechanic" to finish the job.
