adjusting valves? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2012, 06:37 PM
adjusting valves?
Hey!! I have a 88 GMC 1500 4x4 I've just recently had the heads an all the gaskets replaced but the guy said the valves still need adjusted a little more so I'm trying to figure out how exactly I would go about it?? I've been told to start it w/ the valve covers off an the truck running but not so much more detail the turn here an turn there. Honestly I'm mechanically declined when it comes to the inners of a vehicle. Any advice will help. Thanks!!
Old 07-22-2012, 08:21 PM
327NUT's Avatar
Well to start with ...."the guy" who did the repairs should have adjusted the valves properly before he got it back to you. You don't send it out telling the owner that the valves need adjusting a "little more", they are either adjusted or they aren't. Since you're not mechanically inclined and therefore can screw up the valve adj. procedure I would take it back and tell the "mechanic" to finish the job.
Old 07-22-2012, 10:35 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: Test Drive (finally)!
First, you need to find out if the the engine has hydraulic lifters (easier to adjust) or solid lifters (harder to adjust and requires adjusting every 3,000 miles or so). Assuming this is the original 88 engine, they should be hydraulic.
Old 07-23-2012, 12:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here is a page w/instructions to set hydraulic lifters on your SBC engine.
valve adjustment, valvetrain
adjusting valves badknuckles Hotrodding Basics 3 04-24-2011 10:45 PM
Adjusting valves Classic Ed Engine 2 04-06-2006 05:38 AM
Adjusting valves Classic Ed Engine 8 03-31-2006 11:24 AM
need help adjusting valves 67bird Engine 5 09-23-2005 10:49 AM
Adjusting Valves EBlack36 Engine 4 08-06-2004 10:16 PM
