Adjusting Valves and Oil mess(or not in this case) - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2005, 09:38 AM
I adjusted the valves on my 87' 350 block and notices that oil was NOT getting all over the place. It was just running down the
valve rockers from the lifters. Its this a problem?
I always read how messy this job can be with the engine running, but not one drop got on the headers.
My oil pressure is good at idle and at higher rpms. Opinions or ideas?
Old 08-31-2005, 10:04 AM
Siggy_Freud's Avatar
If you believe the guage to be accurate and you are getting roughly 10 PSI per 1000RPM then I wouldn't worry too much about it. I can adjust mine while running and it doesn't get too messy (though IMO adjusting them while running isn't the proper way to do it).
Bringing history and technology together.
Old 08-31-2005, 10:15 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I do not adjust mine while they are running.
Old 08-31-2005, 10:18 AM
So I guess there is no problem. I did notice that once I started the motor, it took about 15 seconds before oil began to run down the rockers. I wonder if I should go to a thinner oil....
Old 08-31-2005, 02:47 PM
What oil are you currently using?
Old 08-31-2005, 05:42 PM
steve t's Avatar
ex biker, now hotrodder
thats the shad-tree way, but i been doing it for years with no problem, just work fast
Old 08-31-2005, 11:28 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
If you are using used push rods they may be getting clogged up with gunk. Different push rods have different size holes in the center. Some oil better than others. I tried a set of Speed Pro Moly pushrods and they were pumping so much oil. I thought it might drain my stock oil pan at high rpm. I switched over to a set of Comp pushrods. If this is a new motor with new push rods. I would assume you never primed it first. When priming a new motor it can take up to 5 minutes to get oil to start coming out of the pushrods. If you started setting the valves before the lifters were pumped up completely. I would go back and do it again.
high volume and high pressure oil pumps can destroy cam and distributor gears! Knobie Engine 75 02-13-2011 02:22 PM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Oil breathers and pcv valves scheetz93 Engine 6 06-01-2005 01:49 AM
how to prepare a block blndweasel Engine 14 08-15-2003 12:28 PM
valves sucking oil wrenchturner Engine 3 05-27-2002 04:42 PM
