Adjustment tool for TPS screw - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2005, 09:35 PM
sabino56's Avatar
I just replaced TPS sensor on 85 Caprice 305 w/ 4bbl quadrajet. Old sensor was broken. After replacing, the check engine light came on and one possibility of code was TPS out of range. I checked voltage and it was out of range. So - I try to adjust it and the screw doesn't have a slotted head - it's a little hex head around 2mm and I can't find a tool small enough to get in there. I've looked all over, Sears, Autozone, etc. and can't find something to adjust it. I bought a carb rebuild kit thinking maybe there would be a little tool in it - no luck. I assume I could buy special tool at dealer.. but I'd like to find one somewhere else! Anyone know where to get the adjustment tool?
Thanks
Ed
Old 11-27-2005, 06:11 PM
aka Duke of URL
-THEXTON TOOL NO. 362-
setting points on sb chevy frackster66 Electrical 14 03-22-2008 11:33 AM
General Motors starts using new type of screw Jon Hotrodders' Lounge 9 09-18-2005 01:34 PM
Holley choke set screw lluciano77 Engine 11 08-05-2004 10:20 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
air screw adjustment? Trav Engine 6 09-29-2003 06:52 PM
