To advance or not to advance? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2005, 10:14 PM
I have a small block chevy (327 .030 over. I have been getting various advice on where I should set my advance. It is strictly a drag engine. It is set at 44 total advance now but I heard that 36 or 38 would be better. Any ideas?
Old 08-07-2005, 10:24 PM
347mustang's Avatar
depends on what the car-engines wants..but i would yes that 44 is too much...38-40 is good on most motors...we run 40-42 on our motors but thay are achoul motors and are 14-1 compression..motors...
Old 08-07-2005, 10:55 PM
BigDawgsEatFirst's Avatar
400SBC4Life
run it now ,see what your e.t. is ,than run it at 36-38 and see your e.t. and keep adjusting til u get lowest possible time................
Old 08-08-2005, 07:02 AM
to advance or not to advance
I ran it at 40 advanced and it turned 12.8, then took it up to 44 and lost 4 tenths. People are telling me small blocks like a lot of advance, but I still think it should be in the 36 to 38 range.
Old 08-08-2005, 07:56 AM
347mustang's Avatar
if you lost e.t at 44 than its to much
Old 08-08-2005, 08:55 AM
Last journal entry: PICTURE TEST
timing
Every combo will like something different.... If you went back to 38 deg and the car ran faster then you are going the right direction.... Keep a close eye on your plugs for signs of detonation while you are trying different timing settings????
What heads??, distributor??,, Is it locked????
Keith
Old 08-08-2005, 09:32 AM
johnsongrass1's Avatar
Race it, Don't rice it!
If your getting away with that much timing and not burnin down engines. You must be super rich. You'll go quicker with a leaner mixture and less timing. OR you heads are really poor designed.
Old 08-08-2005, 09:48 AM
Technical Support Barry Grant
Ignition Timing.
Timing is a factor of your compression ratio, cam profile, and combustion chamber design. There is not a "right" or "Wrong" when it comes to timing. I've got one small block block that runs best at 54 degrees, I have another engine that runs at 26. Give it what makes it happy, but as stated earlier, if you can change the timing that much, and not hurt the engine you're pretty rich, and need to take care of that first. You can tell a lot about timing by reading the heat on the spark plugs.
Old 08-08-2005, 03:12 PM
SBC's like a lot of initial timing with a big cam (20 degrees). And most sbc run best with about 40 degrees of total timing with older style heads and about 36 with fast burn type combustion chambers. So I think you should start with 20 degrees initial and 36 to 40 degrees depending on head design. Then fine tune the timing at the track.
Old 08-14-2005, 08:18 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
timing
Geez, start at 36 total at 3000 rpm and experiment. Drag times are not the end-all. Most drivers are not consistent enough. With no more info this is sort of asking...... how much gas mileage will I get?
Old 08-14-2005, 09:51 PM
1982 SS's Avatar
Flamethrower
Last journal entry: More Cooling fan pictures.
Most drivers aren't consisten eonugh?!?
I can knock off 15.268 to 15.277 all day long. That's shifting manually too.
Anyway, I have currently about 24-26 total on my 383. It wants more, but I am trying to keep a sane initial and 12-14. I had it pushed up once through emissions, (a friend was doing it and advanced it bit and it passed) I did not have track data, but it seemed to run good. I can only say, give it as much as it wants without detonation. Man I need to take care of the low advance I've got...
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Vacuum advance hooked up directly to manifold....is this bad????? Steve-0321 Engine 66 08-21-2009 06:37 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
