Advanced Design Rear end swap with impala? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 09:15 PM
Does anyone know the width of the 1969 Chevy Impala Sedan rear end?
There is a 1969 Chevy Impala Sedan for sale locally for parts that has a 350 engine and 350 turbo tranny. I am interested in it but I will definitely buy it if I can use the rear end from it. I am asking because I haven't been able to find any info online for the width of the 1969 Impala. I know the camaro, nova, corvette, etc. rear ends sizes, just curious about the Impala.
Old 02-14-2011, 09:27 AM
big gear head's Avatar
High Performance Rear Ends
Are you wanting to use the Impala rear end in another Impala? If you are then it will fit from '65 to '71. If you want to use it in another car then it's going to be too wide. The Impala rear end is a little different from other car rear ends. It uses the truck axle bearings and brakes, and it may have the truck 5 on 5 bolt pattern.
Old 02-14-2011, 09:51 AM
I was wanting to swap it into my '49 Chevy truck. The truck will work with 58"-60" rear axles.
There is a 69 Impala for sale locally for parts and I am very interested if the rear end is compatible.
I know many of the Chevy passenger cars will fit, just not sure about the impala and there isn't really any info on the 69 as far as rear axle.
Old 02-14-2011, 10:52 AM
Wiki Edits: 49
I believe you'll find the Impala rear is way too wide. Best look for a mid 70's Camaro or Firebird. They are exactly the correct width.
Centerline
HotRodsAndHemis.com
Gun Control: The theory that a man found in a dark alley in a pool of his own blood, beaten, strangled, and left for dead is somehow morally superior to a man explaining to police how his attacker got that fatal bullet wound. - Anonymous
Old 02-14-2011, 11:19 AM
http://www.impalas.net/forums/forumdisplay.php?f=12 Check here for information on the Impala rear end.
Old 02-14-2011, 11:42 AM
thanks guys. I appreciate it. I thought it would be way too wide.
Old 02-14-2011, 04:11 PM
I have used a 69 Impala rear in a AD truck with no problems. 65 to 70 Impala are within 1/2" to being the same as the 70 and up Camaro. 71 and up Impalas are about 4" wider than a Camaro.
Inline 6 Swap for a newer design jpd37 Engine 6 12-01-2010 10:38 AM
1959 Impala seats(Spider Web Design) 54merc Interior 5 01-23-2010 06:26 PM
"Out To Pasture"---Advanced Design GMC....56K warning Chevrolet4x4s Hot Rod Art 7 07-22-2008 10:39 PM
Rear air suspension design ccrodder Suspension - Brakes - Steering 12 07-24-2006 11:14 PM
Help...rear suspension design questions FrankR Suspension - Brakes - Steering 1 06-02-2006 07:50 PM
