Originally Posted by vinniekq2
set your timing to 35 degrees at 3,000 rpm,rev engine higher to see if timing still increases? let the engine idle and see what you have for static timing.Road test car for ping.add 2 degrees at a time until it does ping.set back 3 degrees from there.That is your maximum timing.That does not mean its the best.
when you have figured the maximum timing and you know what the static timing is,come back and repost
Sorry to sound so ignorant... How do I check "static timing"? That's a new one to me. Once again, sorry to sound ignorant.
