Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Advanced Timing Question for built 4.3
Old 10-09-2012, 10:54 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
no load,no vacuum at idle,is the static timing.3,000 rpm in park,no load is full advance(or should be)This is just a starting spot and will get you very close if you follow this procedure.
recurving the advance takes time/or money.(both)
