Originally Posted by vinniekq2
no load,no vacuum at idle,is the static timing.3,000 rpm in park,no load is full advance(or should be)This is just a starting spot and will get you very close if you follow this procedure.
recurving the advance takes time/or money.(both)
I also forgot to mention that it doesn't idle at factory. Factory is 750, it idles at 1250. All sensors and etc are new.
