Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Advanced Timing Question for built 4.3
Old 10-11-2012, 04:50 PM
S10BlazerBuilt S10BlazerBuilt is offline
Originally Posted by LATECH View Post
Checking the timing on a electronic injected engine is not what you are thinking here. Timing adjusts differently in closed loop than it does in open loop. AND the engine needs to be operating under load to be able to actually read the true timing that is being dialed in to the PCM..
If you have a scanner, it will read the amount of timing being adjusted into the system , just read the live data while driving.
Closed loop conditions are usually
At least 160 degrees engine temp
Gear selector in drive(if automatic)
Active O2 sensor
Then you can throw it into gear, stomp the gas, watch the roadspeed vereses the ignition timing and RPM on the scanner. Then you will be getting closer to what you need to know to start with
Also, if the knock sensor is hooked up and working, if it does get too much timing, the knock sensor will signal the PCM and back the timing off, roughly about 3 degrees each time it happens.Eventually it will"learn" where it needs to be.
The drive method you had for setting the timing in your first post was probably the way to go.
You can dial in more base timing, but the knock sensor should keep the advance curve from going to an excess , which could cause engine damage.
Thank you. I was thinking about getting a advanced timing kit for the HEI so I could change the fuel curve to do it's thing in the lower RPMs. I may go that route. I may have to advance it further to lower the idle to where it needs to be. Then adjust for total time. The one thing I am wondering... Doesn't Initial time change in the procedure? I mean, set initial, plug ECM back up, then adjust total @ 3500 RPM... Either way, the distributor is being turned... Does the ECM store the initial time setting and adjust for what it needs at that point?
Also, one other thing bothering me... If Comp recommends 6-8* and it's not working as far as idle goes, will advancing it to where the idle is proper damage anything?
