Advanced Timing Question for built 4.3 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-11-2012, 07:17 PM
LATECH's Avatar
Thats pretty much it.
Fact is stranger than Fiction
  #17 (permalink)
Old 10-11-2012, 07:49 PM
InDeep****Now
So why the heck did the engine builder tell me to take all the steps I mentioned, in regards to setting initial, and then adjusting after the computer was back in control?! lol Damn. I guess maybe he was assuming I was going with a carbuerated setup?
  #18 (permalink)
Old 10-11-2012, 07:52 PM
LATECH's Avatar
That is prolly what he thought. I had to re read the first post, and I saw TBI both times. I see a few others here missed that as well.
Whats important is that all the guys here were truly iterested in helping, its all good.
Oh , and you can have more intial timing than factory, as long as the knock sensor circuitry is working, the upper limit will be controlled by the PCM.
Also, did you perform a minimum air rate adjustment after the mods?
You should look at the scanner live data to see where the fuel trims are as well.If it runs lean, you may need to tweek something there.
  #19 (permalink)
Old 10-11-2012, 09:54 PM
InDeep****Now
The only thing I can tell ya, is that it's getting more air and fuel than stock. I have a K&N filter, and high rise injector spacer, AFPR, and running 10% more fuel with Venom injectors, and Edelbrock chip. In other words, if I want real tuning, taking it to someone with a dyno who will be able to tune it and reprogram the prom for the performance I want would be my only option? Right now, I guess all I can do is play with initial time, and HEI distributor advance kit. No pings or smoke, no damage? How much room do I have to play with in this engine as far as initial timing? Any ideas? I really don't wanna drop any more money into, except for a performer intake, and ported polished tbi, and $3250 later I don't wanna damage it. Only got 6K for mileage. The timing advance kit for the distributor would allow for some adjustment for the fuel curve.
How do I do the air rate adjustment?
  #20 (permalink)
Old 10-21-2012, 07:25 PM
InDeep****Now
OK initial has been set to 9* BTDC Then I hook up the ECM back up static idle is 22.5*BTDC. At 3500 RPM, when the mark it at it's peak, it's hittin 35* BTDC. Comp cams doesn't recommend going beyond 8* initial But the builder said 10* was fine and that total time should be 37* BTD. She idles higher (1250) at those settings. Where it's at now, it still idles at 1000 which is a touch high. I'm going to examine the exhaust manifold gaskets to see what's up. (Still getting code 13 after 60MPH is reached)
Advanced timing 454 turchiac Engine 15 05-15-2012 04:01 PM
New motor wont run unless the timing is way advanced z-adamson Engine 18 03-30-2012 05:12 PM
SBF - Wont run unless timing WAY advanced?? z-adamson Engine 9 01-02-2011 02:11 PM
40 degrees advanced timing to run kleen56 Engine 7 11-08-2010 10:35 PM
locked advanced question? chevelle4542speed Engine 6 05-12-2006 10:09 PM
