Advancing Cam Timing ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-21-2008, 10:33 AM
chevy350_Camd's Avatar
VROOOM !!!!!!
Last journal entry: This is the Rough Draft of the V8 Frame
Ok I know on double roller there is 3 keys, Advance, Retard and Stock.
I have been wondering what would happen If you set your timing Advanced or retarded on a 350 sbc. Would It have more low end, advanced ?. What does it primarily change ?. Can it increase your Compression ?. Can you even see a change in power ?. Thanks
Old 02-21-2008, 11:00 AM
Wiki Edits: 27
I forgot
one way increases top end the other low end torque. Ford retarded the 460 cams in the 70's so they could meet emmision standards without egr, to save a few bucks they lost about 30 horses doing it... on a 460 you put it back together with a stock cam dead on by using a 68 t bird crank gear . I don't know if gm did that also
Old 02-21-2008, 11:16 AM
techinspector1's Avatar
Wiki Edits: 326
advance or retard????
Old 02-21-2008, 11:17 AM
i almost didn't respond to your post kid. but advancing the cam will increase low speed torque, retarding the cam will increase high speed HP and torque. if i set up an engine i always go with the advanced, eventually chain stretch will bring it back to close to "0". if you retard it you will just behind the "8 BALL". for a street motor, advavcing the cam is the way to go!!! now, if you are building an altered (see previosed post) then retarding the cam is the way to go...
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 06:12 PM
Help with timing Chain and timing cam install LXZ590 Engine 7 12-08-2006 11:01 PM
adjusting cam duration by using smaller/larger timing gears onebadmerc Engine 5 03-17-2006 02:36 AM
Cam timing KNanthrup Engine 4 08-18-2005 12:15 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
