advantages of 1.6 rockers ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2008, 05:27 PM
In the process of building a engine , will the use of 1.6 or 1.7 rockers allow for a smaller cam and result in more clearance between the rods and the cam Than say a 1.5 ratio ? and if so is it a significant amount ? All I have bought so far is the parts to assemble the short block . I have established the cam specs but have not bought one yet so its not to late to change it .
Thanks
Old 03-12-2008, 05:41 PM
charger528's Avatar
Last journal entry: 1991 Mustang LX Mopar powered Drag car
.320 lobe lift 1.5 rocker .480 gross lift
1.6 rocker .512
1.7 rocker .544
PRETTY BIG DEFFERENCE HUH??
Old 03-12-2008, 07:15 PM
Holder350's Avatar
Auto Parts Professional
1.6 and 1.7 arms are mostly for a "quickly" tune job.
You can take a stock cam, swap the rockers and POW its like a higher lift cam.
IMO this puts more strain on the cam, because it amplifies the spring pressure.
also IMO let the cam do the work!
1.6 roller rockers?? tiresmoke55 Engine 9 09-07-2006 01:53 AM
Considering 1.6 rockers 302 Z28 Engine 3 07-25-2006 06:04 AM
1.5 vs 1.6 roller rockers? Streetmaster Engine 10 09-09-2005 10:27 PM
1.5 vs 1.6 rocker's bowtieorbust Engine 1 03-13-2004 07:53 PM
1.6 rockers vs 1.5 rockers michhotrod Engine 4 05-10-2002 10:12 AM
