We're winning the case!
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 06-13-2009, 02:40 PM
nskeeter99 nskeeter99 is offline
advantages of new are old style chevy caliper
I'm in the process of of putting disk breaks in the rear. I found a place for the brackets to hold the caliper. I can get a bracket for the older style gm calipers are the smaller ones on the later model trucks. I have a set of both style setting on the self in the shop. So is there an advantage of any kind one over the other? And if i decided to worry about the e break at a latter date. does the Cadillac caliper have the same bolt patter as one of these and if so which one?
Skeeter
Old 06-28-2009, 08:23 PM
riceharvester's Avatar
riceharvester riceharvester is offline
I've found that the scientific variables of such endeavors are of no great significance. Rather, the meshing of the intrinsic components is of higher consequence.
Be agressive with the sledge hammer and don't mind the pain of compound fractures.
Old 07-04-2009, 02:12 PM
tnovot's Avatar
tnovot tnovot is offline
You might want to check the threads on the fluid inlets to make sure the threads are good. Also, later ones might be metric as opposed to the earlier ones.
Terry
Old 07-04-2009, 04:31 PM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
caddy calipers require an initial E-brake adjustment
are a pain to bleed
and require frequent use of the parking brake to keep them adjusted.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "advantages of new are old style chevy caliper"
chevy starter, how to wire it? exline Electrical 8 04-29-2009 10:28 AM
305 SBC new/old style chadrock84 Engine 6 02-09-2009 09:12 PM
37 chevy body and style numbers ? 38 old coupe Hotrodding Basics 4 11-14-2008 05:43 PM
the history of chevy v8's savman1 Engine 30 01-25-2008 01:02 PM
HELP 1959 chevy box swap to newer box style big jer Body - Exterior 1 10-07-2002 12:37 PM
