Advantages -pitfalls of relocating parking brake to tranny hump - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-31-2005, 11:07 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
I am at some point going to add a rear disc brake system to the 'stang. The '67 uses a dash mount hand pull for the parking brake. I was reading that this may not put enough force to the cables of the disc parking brake. One site recommended changing to a floor rachet, or better yet a console hump style parking brake.
One of our considerations is to modernize the tranny to a 5 speed TKO 600. This can require a raised tranny hump in the stangs. When I read the parking brake issue, I thought that maybe for our car that it might not be a bad idea to get the whole tranny hump floor section from a late model mustang, along with the parking brake handle etc, then finesse that into the floor pan.
I was wondering if any of you folks had moved the parking brake in this fashion. Were you happy with the change, and the way that the brakes work?
thx
Old 09-01-2005, 01:47 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Look at the Mustang II parking brake. It is a stand-alone unit with its own mounting pan and can be bolted anywhere with a few #12 sheet metal screws. Originally mounted on the tranny hump in the donor car. Comes in all chrome, wood grained, or black and possibly other colors. I have used them in many street rod build-ups.
Here is the one in my Willys beside the MII shifter I am using to shift my '54 Dual Range Hydro.
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Parking Brake Thingy wld bil Suspension - Brakes - Steering 1 07-27-2004 01:30 PM
Installing New Parking Brake horvath Suspension - Brakes - Steering 4 04-08-2004 12:43 PM
Parking Brake setup jpd37 Suspension - Brakes - Steering 6 03-08-2004 12:19 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
