Advice on 700R4 Trans -
I'm running a 700R4 in my 69 C-10 hooked to a 275 HP 350. The truck is used mostly for cruising.....very little drag racing or running hard. Well, the trans has died; the torque converter has given up, and I'm looking at options. Do I rebuild (if that can be done, not sure how far gone it is) or do I go with a rebuilt unit?
As I search the net there are several options of a 700R4 from Mild to Drag Strip versions. Is there that much difference???
Thanks for any advice you might have
