Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Advice on 700R4 Trans -
Old 02-01-2013, 11:27 AM
327NUT's Avatar
327NUT 327NUT is offline
You don't need to "swap" in anything, the 700R4 is not a dog if built properly with the righ parts for a 275 hp cruiser engine. There are thousands of them running around with no problems whatsoever. Now if you have a high hp engine and carpet the pedal constantly then you would go to a built TH400. Do some research yourself so you don't go spending money you don't need to.
