Advice on evaluating engine condition - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-23-2012, 04:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have used Durabond cam bearings dozens of times. They're a good OEM replacement. If you're going to use a premium cam bearing, use ACL.
The Following User Says Thank You to cobalt327 For This Useful Post:
Infinite Monkeys (12-23-2012)
  #17 (permalink)
Old 12-23-2012, 05:24 PM
What do you think of Clevite, or Sealed Power.
Thanks again.
  #18 (permalink)
Old 12-23-2012, 05:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks again.
Haven't used them unless they are the same as Durabond or ACL, just in a different box.
  #19 (permalink)
Old 12-24-2012, 11:17 AM
Originally Posted by hcompton View Post
Dura bond is a brand name for melling and seal power is a brand name for federal mogul. Actually they both make pretty good products. Its not junk. If its in the kit i say run it and dont look back.
Both of those companies do make multi versions of parts with different quaility. Look for the word replacement or performance. Replacement bearings or parts are oem min. Spec. Its ment for factory replacement. They also make a high quality bearing with a similar part number. Check the part numbers one letter diff can mean its a much more expensive parts.
Also bearings dont cost much. Its usally all mark up.
sealed power cam bearings are not full round bearings. they are the style that start out as flat pieces and are formed into a circle. i would not use that style of bearing in anything.
The Following User Says Thank You to Plaintoast For This Useful Post:
Infinite Monkeys (12-24-2012)
  #20 (permalink)
Old 12-24-2012, 11:52 AM
Right now, I'm trying to decide between these two kits.
Sealed power:
Sealed Power MKP6321A-000 - SummitRacing.com
Melling:
Ford 7.5L 1993-1997 Engine Rebuild Kit
Summit one is just a little less, but does not have a new cam, or lifters. I'd like to get a new cam, lifters, push rods and springs.
So really, it's only a matter of a couple of hundred dollars, which is not a big deal.
What are your thoughts on Melling VS Sealed power.
Thanks
  #21 (permalink)
Old 12-25-2012, 06:52 AM
The website RPM Machine have performance master kits also. Check out this kit it has the Clevite main and rod bearings, durabond cam bearings, and other name brand parts. Ford 7.5L 1993-1997 Engine Rebuild Kit
The Following User Says Thank You to cdminter59 For This Useful Post:
Infinite Monkeys (12-25-2012)
  #22 (permalink)
Old 12-25-2012, 08:14 AM
I had checked that one out also. They appear to be the same. Looks like they are adding an extra $70 just to give the option to include break-in oil, which you have to pay extra for.
Or maybe I missed something.
Merry Christmas.
Thanks
  #23 (permalink)
Old 12-26-2012, 03:16 PM
I am reading the info under overview the F460TLLET kit doesn't list any brands of parts used. The F460TLLMK kit gives examples of brands of parts used." Your kit will include parts from manufacturers like Felpro, Clevite, Trw, Sealed Power, Perfect Circle, Melling, Sa Gear and More!!" BTW the $688.52 is the price of the kit without Joe Gibbs breakin oil. I would expect to pay more for name brand parts than generic parts in white boxes.
Infinite Monkeys (12-26-2012)
  #24 (permalink)
Old 12-26-2012, 04:22 PM
You are right, I had read that, but missed making the connection. I wonder if the extra money is for better quality parts. I'm still waiting for the cast number off the block from the machine shop. I want to make sure I order the right kit. The engine has been rebuilt before and so there's a possibility it may have come out of a junk yard, from a different year truck.
I'll call them and ask about the 2 different kits.
Thanks again.
evaluating fresh shortblock Ballpeen Engine 3 02-16-2011 01:23 PM
Just checked in to see what condition my condition was in OLDFORDGUY Introduce Yourself 9 01-17-2011 08:39 PM
Classic Hot Wheels Good Condition or New COndition ArchonRacing Engine 2 02-22-2005 12:19 AM
just dropped in to see what condition your condition is in IROC100 Introduce Yourself 1 12-28-2004 08:23 PM
Evaluating a car's condition tnfarm Introduce Yourself 2 11-17-2004 07:01 AM
