Advice needed: Best Carb set up for 454/450HP engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2012, 02:35 PM
I've got a 454/450HP Chevy Engine in my 66 Chevelle SS (it's a street car)
Currently it has a single 4 barrel
I'm looking to add more power, what would you recommend:
A. bigger 4 barrel
B. 3 Deuces
C. Dual Quads
Old 10-20-2012, 03:49 PM
poncho62's Avatar
Wiki Edits: 5
What 4bbl are you using now.....I believe the 70 LS6 came from the factory with a Holley 780. I bought a crate engine from GM in 1975 and put a 1050 3bbl Holley on it....worked well
Old 10-20-2012, 06:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A. bigger 4 barrel
B. 3 Deuces
C. Dual Quads
If you want more performance, go w/a single 4-barrel. If you have a Holley carb on it now, get the number off the airhorn and see what size it is unless you are sure you know what it is already. If its an Edelbrock, the number is stamped on the base. Other carbs just ask.
It can matter what gears are in it, stick or auto, how you use it, etc. but a popular carb for a mild BBC on the street is the Holley 3310 750 vacuum secondary if you're using a dual plane intake.
You might need to recurve the distributor as well. Chances are you will get more from that than a carb swap unless you're running a way too small (or too large) carb.
Any real power gains will come from compression and camshaft along w/headers and possibly a different intake, depending on what you now have.
Old 10-20-2012, 09:04 PM
vinniekq2's Avatar
A 750 cfm carb is adequate for 450 hp.Changing just the carb wont add much in the way of hp
carburetor recommendation, dual quads, tri power
tunnel ram set up advice/opinions needed please pal Engine 22 03-22-2013 04:53 PM
454 carb and other upgrade ideas needed phatTweaker Engine 25 09-26-2010 04:24 PM
Carb issues, advice needed DeputyDawg134 Engine 6 12-11-2007 01:42 PM
EFI to Carb conversion advice needed 1953 Homer Engine 2 12-19-2006 12:16 PM
General Engine Advice Needed kdj997 Engine 4 01-25-2006 03:07 PM
