-   -   Advice on new paint gun (http://www.hotrodders.com/forum/advice-new-paint-gun-70206.html)
rcm800 09-15-2005 12:28 PM
I am looking at getting a new HVLP paint gun. The one I have seemed to work OK for me but also seemed to be a little inconsistent. Not that I am any paint expert, but I though that as long as I am starting my new project (66 Bronco) I would invest in a better one. The one I have now is a cheap one I bought at Carquest. No real name on it. I would plan on using it now for primer, but would like to get a little better one.
I looked at this one
http://www.spraygundepot.com/scripts...sid=0824050539
What do you think?
Any other suggestions. I would like to keep it under $200 if possible.
I am mostly spraying Nason (or other)bc/cc but may be painting single stage Nason on this project.
Any advice would be helpful. I am sure that there are plenty of searches on this but I wanted a recent update as I know what is available is always changing.
Thanks
Bee4Me 09-15-2005 01:13 PM
That is a nice gun. My first good gun was a D'Ville Finishline and I still use it today.
The Harbor Freight "Purple" HVLP is always a good,cheap gun.
There are a ton of Chinese knock off's on e-bay for cheap as well that do a good job.
The Astro's are another line that have favorable mention.
Most any gun paint's well,It really comes back to air supply being the trouble with most as HVLP requires a large VOLUME of air that most hobby compressors can't supply for a full on paint job.
pink63impala 09-15-2005 02:35 PM
those 2 guns are pretty decent, i used the harbor freight, purple central brand for a while, then i bought the devilbliss finishline. i got mine from the mac tools distributor.
pink63impala 09-15-2005 02:36 PM
the only bad thing about the central gun, is the cap is threaded on, and its a pain if some paint dries in the threads :mwink:
ptcamaro 09-15-2005 03:33 PM
pink63impala
How you like the finishline gun compared to purple HF gun?
Thanks
302 Z28 09-15-2005 03:57 PM
That is why I do a really good cleaning everytime I use mine. Take it all apart everytime, clean it and you will not have that problem.
Vince
Bee4Me 09-16-2005 09:25 AM
IMO, The D'ville paint's base better and the purple lay's clear better. The purple has a larger fan and seem's to atomize a heavy solids clear better.
The D'Ville also has the "bag" cup adapters to make clean up much easier.
You can get a universal adapter kit from D'Ville that will fit in most cup's,some need a little modification,that makes clean up quicker.
I've just alway's preferred a 2 gun system. One for paint,one just for clear.
Rarely do you shoot the 2 at the same pressure and gun settings and trust me,Once you find a setting on your gun that lay's clear smooth,you'll want to weld it in place. :D
You also eliminate the possibility of cross contamination of the 2. Nothing worse than having some color stuck in a gun that comes out in your clear.
Kandy's being the worst as the dye saturates into every possible crack and into the metal's microscopic scale. I have cleaned a gun THROUGHLY and leave some clean thinner/reducer in it for storage and the next shoot open the cup to see some of the residual kandy color in the thinner.
pink63impala 09-16-2005 11:25 AM
i personally like the devilbliss, but you can take another can, and put it on the central gun,and will be pretty good, i like mine, cause it olds almost a quart of material..it does wear your arm out painting a hood or roof when its full!
i also soak mine in thinner til i use it again, just dont soak the plastic tips and the threaded part in thinner, as mine expanded and had to replace it :mad:
302 Z28 09-16-2005 11:35 AM
That is what I did with one of my HF purple guns. I had purchased a gun off the net that came with a 1000cc aluminum cup but it wasn't HVLP. I took that cup off it and put it on the HF gun along with the Devill bag system.
Vince
rcm800 09-16-2005 01:43 PM
Which one from HF are you talking about. Anyone have a link or part number?
Bee4Me 09-16-2005 01:50 PM
Purple Gun
You can get the HVLP aluminum cup which will fit it fine. It's usually on the shelf with the other paint gun stuff if you want a larger cup.
The D'Ville universial bag adapters WILL NOT FIT IT!!!
They will however fit the white plastic one.
302 Z28 09-16-2005 08:58 PM
[QUOTE=Bee4Me WILL NOT FIT IT!!!
They will however fit the white plastic one.[/QUOTE]
They will fit if you drill the opening to fit one of the Devill supplied adapters. :thumbup:
Vince
pink63impala 09-17-2005 06:47 AM
bags are for groceries :D
302 Z28 09-17-2005 12:51 PM
Not these bags, they drastically cut down on the amount of clean up time and solvent used.
Vince
turbosc20 09-22-2005 08:55 AM
What pressure on the gauge of the HF purple do you operate at? I'm new to painting an I've been having a hard time getting paint down the way I want it. I tried putting it at 10 - 20 psi and it just splaters on there. And my fan is all crazy. Any pointers?
Originally Posted by Bee4Me
Purple Gun
