Advice please: Mounting steel to concrete. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2005, 07:28 PM
Rice1965's Avatar
Hi all.
My situation involves trying to fix years of neglect that my father's shop (now handed down to me) has endured.
This is a 90 x 30 foot steel building built on a concrete pad. There are 8 vertical I-beams that are bolted to the concrete pad using studs. The bottoms of these beams and the studs are rusted badly and in some cases the studs are gone and the beams are rotting at the base.
What I'm thinking:
Weld brackets on both sides of each beam (L-brackets with some diagonal bracing) and bolt them to the floor using 3/4 inch wedge anchors.
I tried doing a drawing in "microsoft paint" but it's rather sad. Imagine looking straight at the I-Beam, the dark gray are the parts I'm thinking of adding.
Will this work??? What things am I not considering that I should??? I really want this fixed right so please give input.
Old 03-14-2005, 08:02 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
That should work just fine. Are some of the post rotted clear off? And if so, are you going to support it back up or has it dropped any in that area? When you lag it back into the concrete I would use caution against getting too far out to the edge as by drilling and putting and expandable anchor in that area it would stand a chance of cracking the concrete depending on how it was poured.The more towards the inside the better. Also you need to figure that the lags are holding the garage from shifting. The weight of the steel and siding is holding it down. Snap some pics if you get a chance so we all can see.
Kevin
Old 03-14-2005, 08:30 PM
Rice1965's Avatar
Thanks Kevin.
While the bottom plate on the columns (what boxes the bottom of the I-Beams) have lost about 50% or more of their material the columns are still complete and have not dropped any. Will try getting some pics this weekend.
Old 03-15-2005, 04:18 AM
Looks like a pretty good fix to me. There are also epoxy systems that anchor studs etc, nicely without stressing the slab.
Old 03-15-2005, 05:28 AM
Rice1965's Avatar
Neil, I just did read about those and am liking the looks of that option. Thank you!
Rice
Old 03-15-2005, 07:28 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Hi Rice
A car forum isn't really the right place to be looking for structural information. You should consult a structural engineer. Seriously, we all would love to help, but considering the weight of the building, natural forces, etc. a certified engineer is the guy you want. You may be in the building when a column kicks. Bad scene. Even worse, a nice hot rod may be in there !!
The anchor bolts are inbedded about 12" (depends on geographic zone). I assume they are 3/4" diameter. The drawing shows perimeter clamping. This will not stop shifting. Only lifting. The anchors can still shear. Like I said, I would consult an engineer.
Old 03-15-2005, 12:17 PM
Rice1965's Avatar
Originally Posted by Beenaway2long
Hi Rice
I agree. I was really thinking that among the folks that love turning wrenches there would be some structural/civil engineers. As a physicist I'm not completely in the dark here but really like getting other insights, such as yours, from around the table.
Thanks,
Rice
Old 03-15-2005, 12:54 PM
OG GP Girlie's Avatar
You never know it all...
OG GP Girlie
Alright, this is a bit off your topic, but as I understand it you're refurnishing the existing shop?? I can't help with the structural portion, but how's your flooring? Do you have some type of grating to allow for fluid run-off? If not w/b, I provide the fiberglass grating to Turle Wax for their wash bases. We build it for all types of chemical resistances. I'm jus sayin'.
Old 03-15-2005, 12:55 PM
OG GP Girlie
Tu R T Le....
Old 03-15-2005, 08:31 PM
Here's an idea for you
I ran across this once with some post that were supporting a deck. The round metal post were rusted pretty badly at the bottom. I drilled several cross holes through the post above the rusted section. These were drilled perpendicular to each other and staggered vertically. This was done for vertical support. I put 3/4" diameter steel rods through this that stuck out several inches on each side.
Around all of this, I used a circular preform and poured concrete to tie it all together. In your case, I would probably add some j-bolts into the concrete for tie down support.
My $.02 worth.
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
IRS Advice Th3 T0y M4k3r Suspension - Brakes - Steering 2 08-09-2004 04:24 PM
advice on seat rails darom Interior 3 06-28-2004 11:53 AM
New to air suspention and need advice Mr XXX Suspension - Brakes - Steering 1 05-28-2003 06:39 AM
Single Strand Steel Wire in a Ranchero RAW Electrical 3 10-03-2002 02:08 PM
