ADVICE PLEASE: Semi-permanent Sandblast / Spray Booth Construction - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2008, 05:25 PM
Hi all.
Constructing my ToyRoom at home at last. Like most, my problem is a lack of space.
I need to build a semi-permanent (quickly assembled, durable & easily handled and stored)
"cross-flow" Sandblast/Spray-painting Booth (from steel sheet, aluminium sheet or MDF etc.)
This will be assembled in my main work-area (23' L x 17 ' W x 12' H) and removed/stored after use. A 4-post lift (mobile) will eventually be bought (car storage/alignment/maintenance/washing duty) so permanent assembly is not possible.
Not really looking for the usual temporary timber/plastic sheeting arrangement.
I need something more in line with a permanent, wall-mounted (inverted "U-shaped") exhaust filter assembly PLUS some sort of ("hinged/pinned/bolted") arrangement of panels that will allow me to quickly assemble a (21' L x 14' W x 9½' H) booth for sandblasting and spray painting... and easily disassemble it for easy storage.
Thinking of using 4' drop-light florescent fixtures fastened to external panels (behind glass inserts) for light system with the usual intake filters mounted in the front doors. I'll seal panel joints with DIY rubber gaskets and make it airtight (almost) with strapping tape etc.
Any construction suggestions / pictures / links etc. will be appreciated.
Thanks.
Old 03-01-2008, 06:19 PM
AntnyL's Avatar
If it's something you think you'll use again and again, I'd recommend building panels from framing lumber and plywood. Build 4-foot x 8-foot tall (or whatever suits your space/needs) panels from 2x4's on 24-inch centers and OSB plywood. Cheap and plenty strog. Bolt the panels together with carriage bolts. Build the walls and ceiling this way. Add some neoprene gaskets to the panel ends to achieve the seal you're after. When dissassembled, the panels can be stacked away. You can use corded light fixtures and a few extension cords to simplify the wiring.
For ventilation, build a "window" at each end; one for an exhaust fan, the other for the intake air. Route each to an outdoor location.
Just a thought. My dad used to build houses this way (panel system) in his garage!
Old 03-01-2008, 11:44 PM
This one http://www.1969supersport.com/paintroom.html can be taken down in 4'x8' panels that are glued and screwed together, you can dissasemble it with an air ratchet, handle the panels by your self and just stack them on top of each other for storage.
Rob
Old 03-02-2008, 11:28 PM
Last journal entry: B-body disc rotors
Maybe this?
I bought a $199 portable "garage" with the steel tube frame and a polytarp cover.
Old 03-03-2008, 12:12 PM
Originally Posted by AntnyL
...I'd recommend building panels from framing lumber and plywood. Build ...from 2x4's on 24-inch centers and OSB plywood. Bolt panels together with carriage bolts... Add neoprene gaskets to panel ends... use corded light fixtures and extension cords to simplify wiring.
Some very good ideas here AntnyL. Really a big help. Thanks a lot.
Originally Posted by robs ss
http://www.1969supersport.com/paintroom.html can be taken down in 4'x8' panels that are glued and screwed together... dissasemble with air ratchet... stack them for storage.
Rob
Thanks robs. I copied all your "Spray-booth pages" to my hard-drive months ago; even before I registered. Yours is one of those that made me decide to build my own. Thanks.
What's the inside dimensions freedom53? Thanks.
Old 03-03-2008, 10:18 PM
It's 20x12x8 high - I haven't used it yet, but envisioned some type of venting system perhaps made of old furnace pipe with holes cut in it layed along the lower sides and a fan to draw the air down, with a few furnace filters cut in and duct taped for air inlets on the top or walls. I will also use it for a washbay so I can use the pressure washer inside in the winter. I have a sump and floor drain in the bay where I'd set it up. If you go this route make sure to get one with a light colored or white tarp. Makes it a lot brighter.
Question:Aside from "legalities", garage spray booth conversion tips requested xxxcoatings Body - Exterior 3 08-24-2007 08:08 PM
Advice on first spray gun Hallsy Body - Exterior 1 05-26-2006 01:38 AM
Temp. Spray Booth didn't work very well fordSR Body - Exterior 10 10-07-2004 04:43 AM
Home Built Garage Paint Spray Booth BIGISLANDROADRUNNER Introduce Yourself 4 07-15-2004 02:51 AM
ADVICE ON PURCHASING A HVLP SPRAY GUN STATUTORY GRAPE Body - Exterior 38 05-27-2004 11:30 AM
