Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - ADVICE ON PURCHASING A HVLP SPRAY GUN
Old 01-17-2003, 06:08 PM
paintman1 paintman1 is offline
Gravity feed guns will use less paint because like you said you can run your gun dry. You dont have any extra like the siphon feed. Tip size makes a difference depending on what your spraying. The smaller the tip the more the paint will be atomized by the gun. This helps reduce your orange peel. Use to big of a tip and the paint will come out in bigger droplets leaving you with to much build and a more orange peel look. I found 1.5 works good for basecoats and sealers and 1.3 for clear. If you dont want to use two guns, some companies make a 1.4 that would work well for an all around gun.
