ADVICE ON PURCHASING A HVLP SPRAY GUN - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-14-2004, 02:54 PM
I have been trying to get a comparison on these for a while, and still no dice;
(SATA SAT92xxx series or the DeVilbiss GFG670 , both of these are the new Reduced pressure series)
I think I have read other opinions on the new DeVilbiss, but absolutely no direct comparison anywhere between these two.
  #32 (permalink)
Old 05-14-2004, 03:01 PM
BarryK's Avatar
Sata 92 is an old has been gun! Thats why no ones compared anything to it. It came out in 1992. Things change.
  #33 (permalink)
Old 05-14-2004, 03:14 PM
Must be a misunderstanding or they RE-used a number. This is the BRAND NEW Sata Reduced Pressure gun with digital readout in handle. This gun came out just this year. Here is a full reference number and description, this gun is new from SATA:
SATA - SAT92106- SATAJET RP DIGITAL 2 1.3 PAINT SPRAY GUN W/1L ALUM CUP
I probably needed to use the full number to explain. The other numbers are 92098 and 92086-1. These are the same gun, just specifying a differnt tip size.
  #34 (permalink)
Old 05-14-2004, 03:19 PM
BarryK's Avatar
Sata RP.
Now your talking a real gun if you can afford it, if not go second best. This has all been covered in above posts. Its what you want to spend and how good you are of a painter.
I want no peel and I only spray high solids clears so I cant use the D-gun. A lot of people do and it works for them.
Comparison, its like comparing a Yugo, Chev, Ford to a Mercedes
They all perform at what they are suppose to do but its all how you look when you arrive!
  #35 (permalink)
Old 05-19-2004, 08:41 PM
Hey, I have been out of painting for around two years. The last gun I used was a Sata NR95. I'm looking in to buying the new Sata RP. Is the new RP worth buying, or should I go with the NR95 again? Do you need 1/2 or 3/8 airline for the RP?
  #36 (permalink)
Old 05-24-2004, 09:01 PM
CivicSlayr's Avatar
Hey,
I am spraying my own primmer, will that harbor freight detail gun work, or should i get theheavy duty gravity feed. i am hopeing for imedeate responce, any opinions are welome, i would like to place an order tomarrow.
  #37 (permalink)
Old 05-25-2004, 09:16 AM
sportbikeluvr's Avatar
if you have a big job Id go with this gun before the detail gun, which I just received last week cant wait to give it a try!
FWIW- Ive heard a lot of guys getting great resluts from those HF hvlp guns!!!
  #38 (permalink)
Old 05-25-2004, 05:11 PM
CivicSlayr's Avatar
Thats the one i ordered, i figered that it was a nice middle groung gun. i don't like computers.
  #39 (permalink)
Old 05-27-2004, 12:30 PM
Camarofiend73's Avatar
I've read all the threads relating to HVLP guns and decided to try the Harbor Freight #43430. Used it last night and it worked great. I shot bc/cc (White) on the shop truck dually fender-need to colorsand to get the orange peel but overall it came out great.
