advice on Singer 211 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-23-2010, 12:53 PM
needles
Dan, thanks you have confirmed what I was thinking. The singer designations seem to be the ones commonly referred to. I am a little confused because the needles they gave me say 135x5 130/21 and the other is 135/16 140/22. I believe these are a 21 and a 22 needle but were they using the wrong needles since they are not 135/17? Thank you for all the links to different sites in your messages, I have bookmarked several and the discussion on thread is very insightfull. The loaded bobbins I got with the machine are dymo size D. How does a size D thread relate to say 69 or 92? Where do you order your consumables (thread, needles etc) from. Grant
  #17 (permalink)
Old 03-23-2010, 01:12 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Your machine is a 211 U 166, right? The 211 U 157 uses the 135 X 5 needle system, and all the other 211s use 135 X 17. This is the needle system, and not the needle size. The 140/22 and 130/21 needles you have are the needle size. One is a size 21 and the other a size 22, with the first number being the metric designation.
I think you mean Nymo bobbins, not Dymo, right? I don't know what the "D" means. Pre-wound bobbins come in size "G" and "M". G is about 7/8" in diameter, and M is about 1" in diameter. The bobbin should tell you what size bobbin it is and what size thread it has. In other words, it should say G 69, G92, G138, or M69, M92, and M138. Those are the only sizes of pre-wound bobbins I have ever come across.
I buy my thread and bobbins from a local supplier that only sells to upholstery shops.
  #18 (permalink)
Old 05-15-2010, 07:51 AM
Singer 211A567AB
Does anyone have manuals for a Singer 211A567AB? I have searched high and low and can't seem to find any manuals online.
  #19 (permalink)
Old 05-22-2010, 11:12 AM
Wiki Edits: 22
Here you go: CLICK HERE
  #20 (permalink)
Old 05-23-2010, 05:53 AM
Thanks Dan, but I already have this particular manual. The problem is that it pertains to the automatic features of a 211A, different from an older 21A567AB. I have found several manuals that describe other models that are very similar, but don't specifically cover the 211A567AB. The main differences seem to be the way the machines are lubricated. The closest model seems to be the 211G266. This is based on the illustrations in the manual.
I am new to commercial sewing machines, only recently buying a used one. The tensions were screwed up and it caused the bobbin to bind up and change the needle timing. I have adjusted the timing using specs from other models, but it isn't quite right. The bottom stitch still bunches up. I have adjusted the needle tension all over the map, and can't get it right. Manually pulling on both threads seem to be equal.
Do you suppose I should use the setup instructions and procedures for the 211G266 and other similar models to maintain my machine?
  #21 (permalink)
Old 05-23-2010, 07:41 AM
Wiki Edits: 22
The timing and tension of your machine are not just specific to that model. Tension and timing are as basic as it gets and are the same for dozens of different model numbers. My hunch is you may have a part or parts in your machine that have worn and are more the cause for your problems. If you bought this machine used, you should take it to a sewing machine mechanic and have it looked at, timed, and repaired if necessary. Make sure you have a new needle installed correctly. Is the thread you're using old? If it came with the machine, throw it away and buy some new thread, especially if there are no labels on the spool to tell you what the thread is.
Another problem could be at the bobbin case, where your bottom tension is located. Replace your bobbin case with a new one and see if that helps to solve the problem. When the bobbin case is out, see if there's anything under it like some old pieces of thread that need to be cleaned out.
In any case, take the machine to a pro and have it looked over, it will be the best money you can spend on the machine.
  #22 (permalink)
Old 05-23-2010, 09:58 AM
Once I replaced the bobbin case on my 111W153, the problems were all solved
  #23 (permalink)
Old 05-25-2010, 12:49 AM
Thanks for the advice Fellas. I really appreciate your help. To the shop it goes.
Singer 211 W 155 Coodeville Interior 3 12-30-2009 12:32 PM
singer 211 parts benchracer1 Interior 9 10-07-2009 01:03 PM
replacement pickup truck - your advice please jojo99 Engine 3 04-28-2006 04:48 PM
replacement pickup truck - your advice please jojo99 General Rodding Tech 6 04-28-2006 01:18 PM
