Another question is about glazes. What are some do's and don'ts for that? Any brands to avoid? I have some Z Grip and also have some of the Evercoat body filler thinner ( I think it is called Honey). I have used it when mixing up a batch of filler and it definatly does what it says. Can it be mixed into the Z Grip can and set on the shelf or does it need to be used immediately ( I understand that it isn't hardener but It seems to cause the filler to harden faster when I use it.)
No, you do not build up the surface with the epoxy primer. You would use a 2k urethane primer/surfacer to do that on top of the epoxy. You are already using the best epoxy you can but IMO the SPI. The 2K urethane primer/surfacer is vastly more durable and provides a superior surface for your base color to adhere to than the polyester primer you were asking about.
Vince |
Vince |
[I'm a novice painter so take this info with the appropriate grains of sand - er, slick sand.)
Coupled with Vince's comments about durability, I found Slick Sand a bit difficult to lay out nicely, particularly for a beginner. I had a LOT of orange peel and ended up sanding most of the SS onto the floor. Next one I paint, I'm going totally with the 2K urethane primer along with an epoxy seal coat. The 2K laid down much smoother for me and in the end, because less goes on the floor while sanding, it may just be less expensive in the long run.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
Slicksand isn't a true polyester primer, IMO. It doesn't nearly have the build of a true polyester primer, which is about 4 mils per single coat. You'd be better off using the 2k high build from spi over using slicksand.
Slick Sand A high-solids, extra high-build polyester based primer surfacer that offers excellent adhesion to metal, galvanized metal, aluminum, wood, fiberglass, SMC, and body filler. Ideally suited for large uneven surfaces. MEKP activator included. Vince |
I am aware of the description evercoat gives. Yes it's a polyester based primer but it's just a selling point for evercoat, IMO. A TRUE polyster primer is exceptionally high film build and can't be wetsanded, remember this stuff is sprayable filler. It also needs to be recoated with 2k primer or sealer because, again it is a sprayable filler.
Spammer .
Last edited by willys36@aol.com; 09-04-2009 at 10:54 PM. Reason: Violation of guidelines. Please see: general board guidelines. |
| Need Advice - SMALL Bumper Repair - | deadchane | Body - Exterior | 4 | 05-10-2009 07:58 PM |
| newbie advice | davemad | Introduce Yourself | 1 | 01-15-2009 10:16 PM |
| Which sand blaster do you recommend? | AntnyL | Body - Exterior | 7 | 01-19-2008 07:24 PM |
| Marine enamel paint over tremclad flat black. need some advice. | ElCa/monty | Body - Exterior | 3 | 08-30-2007 04:37 PM |
| sand blasting | akm | Body - Exterior | 5 | 09-30-2003 01:11 PM |
