Advice? suggestions? 496 BBC build - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2007, 06:54 PM
WV hillbilly
Last journal entry: PTL 220CC
Hey, building yet another BBC, this one is street/strip oriented destined for a full weight 72 chevelle.
454 block .060 4.310" bore. probe SRS mid dome forged pistons 6.385" rod
Scat 4340 4.250" stroke crank
Scat 4340 H-beams 6.385"
The cam is a comp cams solid roller 288/296 254/262@.050 .714/.714 108*
Now this is where it gets interesting, the heads I have are Canfield 355"s
2.30x1.88 113cc CNC chambers. with the Probe SRS pistons the CR should be 10.5:1
I E
.100 82 74
.200 176 123
.300 250 175
.400 313 213
.500 350 256
.600 367 284
.700 376 309
.800 380 320
I was going with the 310cc versions but looking at the flow number's the 355's have very good low to mid lift flow numbers, much better than the smaller runner version so this had me thinking to go with the large runner heads with a smaller cam.
the headers are jet hot coated 2" longtubes. 3" exhaust
the intake is a victor JR and a 1050 dommy 2" spacer
the rear gear is 4.10 with 28" tall tires
the tranny is a th375 with a ATI 3600-3800 stall
I think the car will weigh in around 3600LBS.
ADVICE? SUGGESTIONS? are welcome
thanks, 2wld4u
Old 07-29-2007, 09:27 PM
coldknock's Avatar
That increased low lift flow isn't worth spit with a fast moving cam lobe and an engine that can't move enough air to use the extra volume. In other words, it'll be a dog until 5000 and the cam will fall off about 7000.
The car will be quicker, faster and more fun to drive with smaller heads.
Larry
bbc 454 maximum power engine build up rynophilia Hotrodding Basics 12 05-18-2015 11:24 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
need advice, short block build up Blob Engine 8 12-09-2003 06:58 AM
496 build up >>> NEED ADVICE terror385 Engine 5 11-17-2003 08:42 AM
Pontiac Build advice Dottrz Engine 19 08-29-2003 06:22 PM
