rebuild the block stock with hyper pistons. no need to balance or knife edge or arp bolts or 0 deck or line bore.
use a piston that makes 9.5 to 9.75:1 cr with 64cc heads.
get a set of 180cc darts or afrs with 64cc chambers.
use an edelbrock rpm intake with a holley 750 3310
compcam 270H
1-5/8 long tube headers, x pipe, 2-1/2 pipe with dynomax super turbos
hei ignition
The above set-up will work well with a close ratio 4 speed with a 3.55 gear
or a wide ratio with a 3.36 gear.
use zddp oil additive at each oil change (
www.zddplus.com )
Install a 3.75 stroke and make 17% more power over the 3.25 stroke. That is like a free 60hp shot of n02.
for long highway trips, use 9 to 9.25:1 cr, compcam 260H, 3.08 gear, and a wide ratio 4 speed.
