Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Advice tuning holley 600 vs idle circuit
Old 04-24-2013, 11:37 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
The 2 corner idle carbs also idle on the secondaries. its just not user adjustable.
Adjust the secondary opening as required from the baseline setting.
You do not want them completely closed. If the motor wants more base initial timing at idle give it what it wants.
try 24deg at idle.
If you want to play with the idle circuit get a AFR meter/gauge.
