Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Advice tuning holley 600 vs idle circuit
Old 04-24-2013, 01:27 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
If you are convinced the idle circuit is too lean then hone the IFR holes a .001" bigger.
Don;t get all carried away.
Give it more idle timing , first. If it runs on use a idle stop solenoid to allow the throttle to close when off.
Heavy dependancy on manifold vacuum at idle for idle advance will result in a bog when you rug it
as the idle timing disappears.
The .020" T slot pre-setting is not carved in stone. Give it what it wants. Adjust as required.
