advice on welding up trim holes - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2006, 02:17 PM
black66's Avatar
www.airriderz.com
What is the proper step in welding up the trim holes on my six six impala? Thanks....
Old 04-07-2006, 02:25 PM
35WINDOW's Avatar
Last journal entry: Engine!
I have always liked Ron Covell's method-if you have a hand punch (Roper Whitney and the like) punch out some Disc's slightly larger than the holes, use a Unibit to make them the right size (or Drill) and put them in the hole. Then, use a Hammer and Dolly and "set' the Disc's in the hole and spot weld in. I do not like the idea of putting a piece of Copper or brass behind the hole and Welding the hole shut-too much heat-just my .02-
Old 04-07-2006, 05:32 PM
gator412's Avatar
1955 2nd series Chevy Pick Up
Last journal entry: Body work and U bolts
I am no expert by any means but......I used the copper behind the hole method. The copper actually kept the fender pretty cool. In fact I have one of the holes that did not need any filler on it after I was done grinding the weld smooth. Yea that even impressed me. The holes I had to fill were about 1/2" diameter. They were large! But like I said I am a rookie just taking my first body working class...so take my post with a grain of salt. You can check out my work in my journal. (A shameless plug...plug weld that is...lol)
Old 04-07-2006, 06:12 PM
Race The Truck
Last journal entry: Son's Truck
I use an alum plate Because it draws all the heat in to the plate keep warping from happening.
Craig
Got a welding coach cboy General Rodding Tech 61 10-28-2005 09:03 AM
filling bumper holes 6speedwagon Body - Exterior 2 05-16-2004 09:24 AM
Welding holes - answer to PM from Ken willys36@aol.com Body - Exterior 2 03-17-2003 07:48 AM
Filling up holes in body, including rust holes Mr.56Chevy Body - Exterior 5 12-12-2002 11:55 AM
Worried about welding Mav Body - Exterior 18 11-23-2002 08:42 PM
