unscrew rusty lines....
HI,go to NAPA and buy the brake line wrench,its open about 1/4 of the circumference,to go over the line..DO NOT use an adjustable wrench..
Hi boatbob2,
I am in Bulgaria, Europe, so no NAPA here at all ![]() I am ordering parts from rockauto.com as their shipping cost is reasonable ![]() I think I have the type of wrench you mentioned. It is almost closed hexagon inside with a cut just to let the pipe in but not the nut. Am I correct? Thanks, Ivo |
The wrenches are called "flare nut wrenches".
As for other parts, you've covered most of it. I would also recommend getting a caliper mounting hardware kit and pins for the front (this includes the bushings, O-rings, and mounting pins). And since you'll be pulling the front rotors to have them surfaced, you should replace the wheel bearings and grease seals. |
flare wrench...
Hi Ivo,you are correct on the wrench,welcome aboard,that monte carlo is probably the only one there!!
Hi joe_padavano,
Thanks for the info. I have caliper mounting kit, just forgot to mention it. ![]() I have this type of wrenches as well Does anyone know for sure what thread size are bleeder screws for this car? I see they sell metric and SAE thread sizes. My ones are so rusty that I cannot determine anything from them ![]() Also, what is the size of banjo bolts front and rear? Thank you, Ivo |
| 78 monte door panel swap | tyson | Interior | 0 | 02-14-2004 08:44 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| 78 monte rearend change advice | tyson | Transmission - Rearend | 1 | 07-29-2003 10:02 PM |
| 78 Monte | Halloweenking | Hotrodders' Lounge | 6 | 07-13-2003 02:30 PM |
| How about a 6-speed in a 78 monte carlo | CrazyT | Engine | 2 | 11-24-2002 04:55 PM |
