advise on PG epoxy D834 DP40 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2010, 04:28 AM
Hi all
I sprayed my shell with PPG epoxy (D834 DP40) about 6 weeks ago. Since then I have finally finished the metal work on my doors and their gaps and am now skimming and blocking them off. So I am sanding over filler on the doors and epoxy on the fender and quater.
Trouble is sanding the car dry. Going over the epoxy pills the paper like crazy. Is this normal with epoxy as I have not used it before. The coverage of the epoxy is excellent and it is definately cured.
Wet sanding is working fine but I usually work dry at this stage.
Any help, advise and others experience welcome.
Thanks
Old 03-01-2010, 06:14 AM
BarryK's Avatar
A lot of times overseas formulas are different then the same product in the States, some epoxies dry sand and some don't, does not mean there is anything wrong with the epoxy.
However you should check with the paint supplier to make sure the epoxy is suppose to be this way, just to make sure there are not other problems.
Not knowing if it is a different formulation, there is no way we can advise from here.
Old 03-01-2010, 06:19 AM
Just got back from picking up more supplies at the paint shop. There was a bodyshop owner in there getting suplies too and he said that is does pill the paper up quickly and to keep doing it wet as I have been. So I guess that is the way forward.
Thanks
Old 03-01-2010, 09:26 AM
I have started using Abranet abrasive (open weave stuff) and that seems to work dry on the epoxy. Yay.
Old 03-02-2010, 08:50 PM
BMM BMM is offline
PPG's Epoxy dry sands terribly.
Self Etching primer vs. epoxy primer elcaminodragster Body - Exterior 47 06-08-2009 07:17 PM
Epoxy Prep also sealer question off2wildblue Body - Exterior 3 05-09-2009 01:23 PM
1st bc/cc -- epoxy prep help needed grouch Body - Exterior 96 12-17-2008 12:38 AM
what body panel epoxy to use malibu68 Body - Exterior 6 12-07-2006 02:13 PM
Look What's Coming On Monster Garage!!!!!!!!!!!!!!! willys36@aol.com Hotrodders' Lounge 10 01-20-2004 09:17 AM
