Aerostar suspension swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2014, 12:00 PM
Last journal entry: Start over
I've been going back and forth between using an aerostar or a crown vic front suspension for my Studebaker truck chassis. The crown vic seems to be the trick set up but the one major thing wrong is the width. Because the hubs are so far out, it is necessary to use negative offset wheels which is not the look I want. The aerostar uses a more conventional wheel and seems to be an easy enough conversion. The problem with this one is the dinky brakes and the world's ugliest upper control arm. I was hoping that I could swap another spindle and arm & be happy. Not the case. All of the other Ford options are either too short, too long , or, in the case of mustang, use a strut. It doesn't seem that anything will work without some major re-engineering which isn't worth the time & effort. I guess that I'll end up using a 17 X 8 wheel and some 1 1/2" spacers on the T-bird rear.
Old 01-22-2014, 04:08 PM
Wiki Edits: 27
FFR Cobra kits
check out how FactoryFive Racing uses the Fox mustang spindles, an adaptor bracket and new tubular control arms. You might be abler to mix and match parts, get some
BIG Mustang Cobra brakes with an aero X member.
Old 01-22-2014, 11:25 PM
I had thought about fabricating a " strut replacer" when OI looked at some mustang spindles but is seems like a '98 or so c/v taxi or police spindle might be better as it already is forged for ball joints at both ends. They have 12" rotors and dual piston calipers. I can but turnbuckles from Mc Master Carr and fabricate an upper control arm but then why not fabricate a lower one too and use coil overs? However, there goes the cheap and easy portion of the program. I'm getting more sold on the '03-'06 c/v susp. as the best choice.
Old 01-23-2014, 08:44 AM
Wiki Edits: 27
jag ?
Have you looked at using a Jag xjs, We have a jag under the rear of my son's 22 Dodge lakester, 4 jag xjs rear suspensions on pallets, 2 xjs fronts and 2 Jag F 40' fronts for future projects, We got them at a self serve yard for $ 100-125 each
lots of info if you search on the HAMB
http://www.jalopyjournal.com/forum/s...ght=jag+jaguar
Jag Jaguar IRS into a 46' International Harvester - THE H.A.M.B.
Old 01-23-2014, 08:32 PM
Our local U-pull it has come under corporate ownership and now everything' made of gold. Also, you don't buy a suspension as a unit but each individual piece. Price of everything has doubled.
Kind of wanted to stay away from the foreign stuff. Installed the famous jag rear end under a friend's '40 chev and it looked kind of weak compared to the '87 T-bird unit I'm using. Also they have the chevy bolt pattern. The other possibility was to use a newer dakota frame & suspension. If the spindles can be changed to the earlier type with the 5 bolt pattern then we might have a winner. 11" w/ single piston would be adequate. Been a Ford guy since 1962. Kind of would like to keep it that way.
Aerostar v/s Crown vic. belchfire Suspension - Brakes - Steering 6 12-23-2013 10:29 PM
suspension swap or frame swap? mouse57 Suspension - Brakes - Steering 16 07-24-2013 07:29 PM
Aerostar Body panel repairs CdnSoldier Body - Exterior 3 03-28-2005 05:28 PM
Aerostar anyone? CustomChrome Suspension - Brakes - Steering 5 05-31-2003 07:19 AM
