AF21B 05 Ford 500 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2011, 05:08 AM
AF21B 05 Ford 500
First one of these I've seen.
I have no info on this trans.
No ch engine light of any kind.
Up shifts fine threw all the gears.
Comming to a stop I feel a bund up on a downshift and when you are in OD and step on the gas for kick down I feel the same bind up.
Is this one that has to go back to the dealer for reprograning?
Bob
Old 05-04-2011, 09:12 AM
tnsmith10's Avatar
when will it rain???
Bob
theres a lot that can cause a bind, anything from programming, to internal failure.
just because there is no CEL, does not mean there are no stored codes in the system, and a code reader is not sufficient enough to pull stored codes as they usually only pull current or CEL codes.
now with it having the 6 speed trans and not the cvt, it will have a dipstick that you can check the fluid level and condition.
how many miles are on the car? how is the fluid level and condition? when did the problem start? and last, have you had any recent service work done?
1948 ford f-1, 1981 ford f-150, mustang ll pile up derrick_500 Suspension - Brakes - Steering 6 09-09-2008 01:17 AM
1997 Ford Ford Ranger gear ratio ? mercury man Transmission - Rearend 8 03-23-2008 02:10 PM
ford f100 & newer ford mustang photoshops lowROLLERchevy Hot Rod Art 0 02-06-2006 03:52 PM
1932 Ford rims Kelsey Hayes or Ford motor Co. alf51chevy Suspension - Brakes - Steering 2 09-12-2005 08:14 PM
Ford Racing Visteon Ring & Pinion, 9" Ford ??? acr Transmission - Rearend 2 07-23-2004 09:17 AM
