afco coil over - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2002, 08:28 AM
New Member
Post afco coil over
Has anyone built a coil over front suspension using a mustang II rack and spindles with afco upper and lower strut arms. I need a blue print for the snout and arm lengths. thanks cj
Old 02-15-2002, 11:00 PM
Post
I assume when you refer to AFCO struts you are reffering to the after market a-arms sold buy several what we call in Tx "DIRT TRACK Suppliers".
If you measure the stock Mustang arms you'll find a differance of 4.5" in the length of the upper &
lower"control" or"a-arms". The Mustang frt.end likes A 13" lower control arm. This makes the length of the of the upper a-arm figure out to 8.5 ". If you look at all the after-market mustang frt. ends being sold you find this varies.This is maybe everybodies secret formula-Ha Ha---actually it is what the designer wants the camber setting(tilt of the top of the wheel in &out)to do when the frt. end moves away from ride hieght.
I build my own arms and personally like to use the same lengths as the stock arm when building a street rod . When building a frt.end for a drag car I like to make the upper arm a little longer to reduce the amount of negative camber under acceleration. ON the other hand a car that will be used for heavy cornering I prefer a shorter arm which will cause the wheel inner wheel have less positive camber or stand up straight(in a hard corner)--therby reducing oversteer. In any application I use a 13" lower arm. My personal street rod is a 34'Chevy and I built "indy style "a-arms with Chrysler srcew-in ball joints and rear mounted rack & pinion. weh!nough said?
Old 09-02-2003, 06:20 PM
Saltracer's Avatar
afco coil over
What would the tread width (center to center) be on a standard mustang II style front end. We have a Henry J and it has a fairly narrow stance.
