AFR 205cc LS1 results - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2004, 04:21 PM
firestone's Avatar
http://teamrfc.gospelcom.net
346 cubic inch
stock LS1 short block
AFR 205cc CNC ported LS1 heads (flow over 300 @.700 lift)
1 3/4" long tube headers
FAST intake manifold
224/228 @ .050 .581 lift cam
78mm ported throttle body
stock compression
530hp @ 6500 RPM
475tq @ 4900 RPM
Thats 1.55 hp/cubic inch on pump gas only being rapped to 6500 RPM. Not too bad.
Adam
Old 03-11-2004, 06:00 PM
Rogers Performance's Avatar
Adam is that rearwheel or engine dyno numbers.
mike
ps, i thought AFR was not shipping there heads do to a problem.
Old 03-12-2004, 10:30 AM
firestone's Avatar
That is an engine dyno. I talked to AFR, and they said that their LS1 heads are still in a testing phase right now, thats why you can't get them. I would assume that once they get all the testing done they would be available for the market. you can see the dyno info on their website www.airflowresearch.com .
Adam
Old 03-12-2004, 10:35 AM
Adam do you work for AFR?
Old 03-12-2004, 10:44 AM
firestone's Avatar
No,...I wish.
Adam
