Hotrodders Bulletin Board
#2
They can be used with any style cam if the correct valve springs are installed. The 210's are mainly for very large cams & higher rpm range. The 195's would be a better Street/Strip head. AFR's flow very well with smaller ports.
#3
IMO
Some of that roller cam recommendation is that to take advantage of that head with high lift and long duration will require very stout springs, which in turn will destroy flat tappet cams, unless nitrided and using oil hole face lifters. Still rollers will make more power. More than 300# over the nose times 1.5+ rockers, will smoke a flat tappet cam unless precautions are taken. |
Back to top |
Similar Threads for: "AFR 210 help"
| AFR or Vortec heads? Cam? | rodent | Engine | 17 | 03-05-2009 05:46 PM |
| 383 Recipe | Sweet Lu | Engine | 9 | 10-20-2007 12:01 AM |
| AFR head question | Mustangsaly | Engine | 8 | 08-02-2006 08:55 PM |
| AFR Heads ? | DTL504 | Engine | 2 | 05-03-2004 08:27 PM |
| Intake port matching AFR heads | 406chevelle | Engine | 2 | 01-16-2004 05:26 PM |
