-   -   AFR Dart Canfield for blown SBC (http://www.hotrodders.com/forum/afr-dart-canfield-blown-sbc-69847.html)
wrench9 09-09-2005 09:41 PM
Which heads would be best for my 36 chev coupe it has a 350 with a BDS blower 10 psi boost it is used mainly for street but some strip I need to stay with the 200 cc intake runner to match my intake I will be upgrading the cam also i currently have 441 castings with some valve and port work and a hydraulic cam any info is greatly appreciated
Thanks
firestone 09-09-2005 10:16 PM
Without a doubt the AFR 195's will make the most hp. You will be looking at around $200 more for a set of street CNC ported AFR's, but it would take alot more than that to get an as cast head to the point of the AFR's.
This may be an interesting article for you.
http://airflowresearch.com/articles/article41/A-P1.htm
Adam
Rick WI 09-10-2005 06:40 AM
The Dart Iron Eagle Platinum would be an excellent value for you.
hrodgmc 09-10-2005 02:47 PM
I agree the iron eagles are the best for the $$$, but the AFR have the thickest deck of any in the industry. I believe they would be the best for the application if money is not in question.
