AFR Guage / recommended oil ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2012, 11:41 AM
Which brand AFR guage do I need to buy to get my 383 weiand 671 blower 2-750 holley's tuned up ? Does the edlebrock one have the heated 02 sensor , and I guess I need someone too weld coupling in the header for 02 sensor ? What oil do you guy's recommend for my blower motor , it is very hot and humid in houston,Tx . I was told I should not use synthetic Can anyone explain ! Thanks for any advise .
Old 05-27-2012, 12:47 PM
cool rockin daddy's Avatar
1.21 giga-watts???!!!!
Take it back to where you had it built and have them do it.
Old 05-27-2012, 01:02 PM
Can't !
Bought car in West Jordan , Utah and had it shipped too Houston, Tx ! I wish it was that easy . Motor was built by RPM MACHINE , it's 4500 feet sea level there !
Old 05-27-2012, 02:11 PM
68NovaSS's Avatar
Wiki Edits: 9
That's a GREAT idea, but more sarcastic than realistic...
Several of us are using the Innovate system, having the bung welded isn't a big thing, it just has to be off the bottom of the header to avoid standing moisture, bungs are included in their kits. If you didn't need full time monitoring, Innovate also has clamp on tailpipe pickups.
I don't know why not to use synthetic, unless there's a need for more ZDDP protection, extreme cam lift, etc. I don't use synthetics in my blown Nova, it's full roller, and just my preference.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 05-27-2012, 02:19 PM
F-BIRD'88's Avatar
Yada Yada Yada
Why don't you find and work wth a prefessional builder /tuner that does these Roots supercharged motors in your local area.?
If you really have to ask these questions (lack of experience)
This is probabily your best bet.
learning to tune correctly takes time and patience.
You have learn to walk before you run.
You do not want to cut your teeth on a expensive supercharged motor.
When bad things happen, they happen much faster and more violently on a supercharged motor. $$$$$$$$$$$$
You will probabily save money in the end by paying a good local pro to get it dialed in.
Paying a pro to Sort out the tuneup on a engine dyno is invaluable. You catch and avoid a lot of costly issues.
I do a lot lot lot of my own stuff but have been doing this for years and years.
you need to go easy on the tuneup for on street driving with pump gas.
its has its limits.
Old 05-27-2012, 07:20 PM
"That's a GREAT idea, but more sarcastic than realistic... "
Glad you caught the sarcasm. As F-Bird posted, this guy is in way over his head on this car. I'll just leave it at that.
Old 05-28-2012, 10:55 AM
T-bucket23's Avatar
Wiki Edits: 26
They also make no weld straps wit a bung in them for temporary testing. Summit sells them.
Chet
Old 05-28-2012, 05:02 PM
68NovaSS's Avatar
Wiki Edits: 9
He's on a bit of a learning curve with boost, but not a noob to performance motors by a long shot, he's an ex unlimited outboard racer, built outboard motors spraying NOS at over 12k rpm's. I don't say that to impress you or anyone else, but I think your remark was short sided and should have been worded differently. You've run off more than one new member with your sarcasm and assuming when a poster doesn't word his entry just right.
Oil Pressure Guage = Fuel Pressure Guage topdogger Hotrodding Basics 7 06-24-2007 08:55 PM
Tranny Temp Guage = Oil Temp Guage? topdogger Transmission - Rearend 2 06-21-2007 08:59 PM
what grade of oil is recommended for an older sbc 350? batman09 Engine 7 08-23-2004 11:28 PM
oil pressure guage brian400ex Engine 6 04-16-2004 12:18 PM
oil pressure guage JUS10 Electrical 14 03-17-2003 03:33 AM
