I think you should choose the 383. In your local of so-cal it shouldn't be too hard to find a 350 block and the scat stroker 9000 series cranks are getting cheaper and cheaper....flat top pistons....AFR 195s. Victor Jr. intake 750 vacuum secondary carb and 1"3/4 headers....to answer your question pretty much any of the aluminum heads for chevies are great. Most are $1200.00 assembled! The bad thing is you're going to need to spend as much in the car as you put in the motor! Good trans/rear and tight suspension to put the power to the ground. Pick torque over top end HP on the street and you will be waay ahead of the guy you're racing by the time he hits the powerband on his cam.
I have AFR 190cc aluminum heads with 68cc chambers on my GM replacement 350. I originally used an Edelbrock Performer intake with an Edelbrock 650cfm carb. Ran good but not what I expected. I switched to an Edelbrock RPM Air Gap and a Holley 770cfm Street Avenger. MAJOR difference. Runs very strong yet cruises well with no bad manners.
As to running a 327 versus a 383; definitely go with the 383! You will not be disapointed. |
I would have to agree with corenle, if you go with the 383 I would use 195-210, I'm using 210s on a 327 they are a great set of heads. All depending on the set up you want. If you want a good street engine with low end torque 195s if you wan that high rev deap breathing race track machine I would go 210. And probably a torque converter with a stall speed around 3000-3500.
But this is just my opnion. |
I have the 195cc street head 68cc straight plugs on my 10.3:1 383. Just arrived 2 weeks ago. http://members.cox.net/cad/cars.htm
Here is your only problem with AFR. If you dont find someone with these heads in stock, you will need to wait approximately 10-12 weeks. Why? AFR doesn't build you head until you order it. Next issue, 210cc race head only comes in 76cc combustion chamber (this will lower your compression ratio---call your piston mfg to determine what cc head you should order). It will cost more to have them milled. The 210 comes stock with roller valve springs and you will need to indicate if you want that downgraded or you will flatten a flat tappet cam in no time. The 210 only comes in an angle plug configuration, straight plug is a special order (non-returnable). 195 head may not clear domed pistons. 195 comes in 68 or 74cc configuration. Also, use ARP head bolts. If you must have AFR, call around for stock. Also, call AFR direct for advice. They will assist and give you their recommendation. Also, make sure the roller rockers you have/are buying will clear the large valve springs that these heads come with. AIR FLOW RESEARCH 10490 Ilex Avenue Pacoima, California, USA 91331 tel: 818-890-0616 CAD |
