after adj valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2005, 07:35 AM
mac350's Avatar
http://www.eastcoastfbody.com/
after adj valves
hey all i am new to the board
my question to all of you is that i had adj my valves on my 350,mind you that i only adjusted valves twice in my life so i am new to this. after i adjusted them the car felt stiff and i lost my brakes. i put a vacumm gauge on the direct port on the carb and it was jumping around like you dont know. is it the valves or should i just give up. any help i would be greatfull
Old 11-07-2005, 07:56 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Valves are probably to tight. If adjusting them while running give the lifter about ten seconds to bleed down every 1/4 turn adjustment.
Old 11-07-2005, 07:57 AM
Welcom . .
try to put more details about ur engine ?
Old 11-07-2005, 08:31 AM
347mustang's Avatar
did you have brakes before you adjusted the valves, if so i would say that you have them way to tight
Old 11-07-2005, 09:24 AM
mac350's Avatar
thanks guys for the replys
ok yes i did have brakes befor i started. i also have a vac can.
i defenetly thaught i had them too tight. i thaught they would be easyer to adj.
i adjusted them wile the car was off. i guess i should do them wile it is running.
ok i have a 350 vortec crate. it has an lt4 hot cam whitch has 525 lift on it.i have a gm hi rise manafold with a demmon on top. i have 9.6to 1 commpression.
Old 11-07-2005, 01:17 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Take an old set of covers and cut the tops out of 'em to keep the oil from flying, makes it not quite so messy.
Old 11-07-2005, 02:46 PM
They need to be adjusted while the engine is running.
You can also buy the oil retaining clips in Summit for around ten bucks I think. The clips lock onto the rocker tips and help keep the job less messy.
Worth it to put bigger valves in stock seats??? sizemoremk Engine 3 08-13-2005 12:19 AM
What kind of machining needs to be done to run oversize valves? Dubz Engine 8 03-12-2005 07:55 PM
Unshrouding valves - how much is it worth? Mad Maggot Engine 6 11-17-2004 07:37 PM
Question on Aftermarket valves & machining heads unstable Engine 9 05-26-2004 08:50 AM
Valves GearHead69 Engine 3 10-13-2003 04:51 PM
