After-market Cast Iron Heads for 406 SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 03:24 PM
Does any after-market head manufacturer make cast iron heads for the 400 SBC with 76cc combustion chambers and 200 cc intake runners? I need 76cc chambers to work with my flat-top pistons to get the compression ratio down to 9.7 to 1 after decking the block to reduce the quench area to 0.054".
Old 06-13-2010, 03:41 PM
my87Z's Avatar
Veteran/Firefighter-EMT-I CRT
i can't find any that make an iron head with 76cc and 200cc runners, but i do see some alm heads but you will pay a decent penny for them. my best advice for you would be to buy a set of 72cc/200cc iron heads as they are of an abundant supply and have the chambers opened up to what ever you want. i would acutally recomend having them opended up more than the 76cc's so you will be able to get a tighter quench. having the combustion chamber on a set of heads opend up is not too expensive, although having it done with steel head will probably cost you a little more than having it done to a set of allm heads would
Old 06-13-2010, 03:47 PM
ericnova72's Avatar
More for Less Racer
Yep^^^, you'll have to buy the 72cc and rework the chamber to 76cc yourself, or have someone do it. Not a hard job if you have some experience with a die grinder.
You might try an authorized Dart distributor, they may have the ability to get a pair special ordered with less metal removed from the face leaving the chambers deeper. I don't know for sure, seems like I've heard they will, but you might have a wait to get them.
Help with SBC Heads. zildjian4life218 Hotrodding Basics 34 01-14-2009 06:42 PM
Holley Iron Heads? SBC KNanthrup Engine 0 04-24-2007 11:56 AM
small block ford cast iron heads k-star Engine 20 12-10-2005 08:35 AM
Welding Cast Iron OneMoreTime General Rodding Tech 3 01-22-2005 05:46 AM
bowtie heads for sbc Eddie Baker Engine 3 11-08-2003 11:02 PM
