after market door fit. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2009, 02:54 PM
I have an aftermarket passenger door that I'm trying to fit on my 59 Chevy Apache. The bottom of the door is not straight as the front end dips down. This makes it too close to the rocker for the correct gap. It is also too tight to the front fender on the bottom 4 inches.
Solutions: Will all the aftermarket doors be the same? Should I grind down that area, reweld. I know that these doors are thin in this area and the skin will probably separate. Will I be causing more problems?
Thanks for your help
Old 09-17-2009, 04:38 PM
Wiki Edits: 31
aftermarket doors almost always provide a poor fit... you'll just have to fit them/ mod them to fit.
Double Hump or after market heads swampwillie Engine 16 06-29-2010 08:06 AM
It's a half price market out there! Arrowhead Hotrodders' Lounge 18 03-18-2009 05:10 PM
Revised Stock Market Terms Oct. 2008 wretched ratchet Off-Topic 3 10-19-2008 09:13 PM
Installing oil cap on after market valve covers rajsid Engine 16 10-14-2008 10:50 AM
Maggie Valley, NC Car Show and Flea Market trees Hotrodders' Lounge 1 07-05-2004 05:08 AM
