after market fuel regulator connections - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2013, 06:35 PM
hi im having trouble finding out on this fuel regulator which is IN or OUT the one on bottom or on side and where can i hook vacuum line up to from the regulator
Old 03-05-2013, 06:50 AM
Last journal entry: 50 Ply wagon
The small tapped hole is not a vacuum line it is for a fuel pressure gauge. There are no vacuum lines on a fuel regulator.
Usually the one located at the bottom is the IN and the other is OUT.
The Following User Says Thank You to sunsetdart For This Useful Post:
liljoe1996miller@aol (03-05-2013)
Old 03-05-2013, 07:39 AM
BigMo's Avatar
In and Out....
What he said, almost 90% of the time, bottim is in, the top or top two are out....and yes, that small oriface is for the fuel gauge (pressure gauge)....hook up vacuum and you will be having some bad days at the ol motor startup area.....maybe some nice fire too......
The Following User Says Thank You to BigMo For This Useful Post:
fuel regulator Camaro820 Engine 3 07-02-2011 11:01 AM
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 02:51 PM
insulating wire connections in fuel tank DaSouthWon Electrical 20 07-04-2008 06:38 PM
Ford fuel pump connections? 1953 Homer Engine 3 02-05-2008 10:18 AM
Device for vaporizing fuel to improve economy released onto market today! club327 Engine 15 05-25-2005 08:47 PM
