After market Pontiac D port heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2010, 04:24 PM
Title say it all, does any one make after market Pontiac D port heads? Looking for something that has higher flow numbers than stock D port.
BT
Old 10-06-2010, 04:31 PM
techinspector1's Avatar
Wiki Edits: 326
Mr. Creech should be along in a little while to shine the light of truth on head selection.
Old 10-06-2010, 05:40 PM
DENCOUCH's Avatar
I hope so...
I kinda enjoy reading his stuff.
Now if I could only get motivated to do something with that 400 bolted to the stand in my garage.
Old 10-06-2010, 06:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Practically all of the aftermarket heads made for Pontiac engines have D-port exhausts. The Edelbrock heads have D-port widely spaced (RA IV-type) exhaust ports.
The OM round port heads were made as a convenience by the factory for the racers using Pontiac engines, not necessarily for a flow advantage, because the close spacing of the traditional D-port heads caused header fitment problems w/ported heads. After the redesign and port changes, a flow increase was seen, even though that wasn't the sole intention.
EDIT- It's worth mentioning there are raised intake port aftermarket heads available, for those wanting to run large CFM ports.
There are those who call any RA IV-type flanged Pontiac head- even if the ports are "D" shaped, as "Round Port" heads. This is true as far as the type of header flange that has to be used, but the ports themselves are D shaped, in most all cases.
Pont. D-port heads had the flat part of the D at the insides of the center ports. Aftermarket heads tend to have the flat part of the D at the bottom of the port.
Old 10-06-2010, 06:59 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here's a view of the Edelbrock ports. As can be seen, the exhaust ports (that Edelbrock call "D-Port", have the RA IV flange, and the "D" is turned 90 so the flat is at the bottom of the port instead of the insides of the center ports:
I would have added it to the above post- except the too short time limit for editing bites again.
Old 10-06-2010, 10:33 PM
WDCreech's Avatar
Grumpy Old Goat Herder
Here's the first, and best, aftermarket D port Pontiac head. http://www.krepower.com/KRE_d-port_heads.htm
Old 10-06-2010, 11:02 PM
Wiki Edits: 326
A roundish port that has to make a turn upsets flow because the port is basically the same diameter all the way through the port. Because the short side radius is.....shorter......the gases do not flow through the port without turbulence. They move quicker around the long side radius and slower around the short turn radius.
A "D"-shaped port is made with the flat part of the D on the port floor, because that's where it needs to be in order to make the port think it is the same diameter all the way along its length. A "D" port tricks the head into thinking that the ports are all the same diameter and straight, thereby minimizing turbulence and aiding flow.
At least that's the way it was explained to me and it makes sense that it works that way.
Old 10-06-2010, 11:23 PM
WDCreech's Avatar
That is correct TI. That's why all of the good aftermarket "round port" heads have a flat floor. Both, my Wenzler Super Chiefs and my Wenzler series II High Ports, that Kauffman did for me, have flat floors and if you ever see a Tiger head, it's the same.
1964 Pontiac 389 Rebuilt (74' 400 Heads) - Have questions... gen_x_forever Engine 15 11-14-2010 11:42 AM
Lt-1 cjajz Engine 13 11-27-2008 10:41 PM
need help pontiac 389 with 400 heads RedFox Engine 4 12-29-2007 09:41 PM
Intake port matching AFR heads 406chevelle Engine 2 01-16-2004 05:26 PM
326 pontiac heads bullheimer Engine 2 10-08-2002 01:49 PM
