After market timing pointer on '93 engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 02:13 PM
staleg's Avatar
Last journal entry: Hand brake
I'm about to set the timing tape on the harmonic balancer.
The engine is a Chevy '93 model 350 1st gen, and the harmonic balancer is the original one.
The TDC marking on that balancer is at 12 o' clock, right?
So I just set the balancer with the marking in 12 o'clock position and put the timing tape on so that the tape's TDC lines up with zero degrees on the after market 2 o'clock position pointer?
Old 04-30-2011, 03:23 PM
techinspector1's Avatar
Wiki Edits: 326
Personally, I wouldn't do this until I had verified that the #1 piston is at TDC.
http://www.crankshaftcoalition.com/w...op_dead_center
Old 04-30-2011, 05:25 PM
staleg's Avatar
I made a piston stop tool out of a spark plug and moved the crank clockwise and counter clockwise to find TDC that way instead and I think I got it pretty accurate.
It didn't mach up with the balancer mark at 12 o'clock, tow.
Thanks
Old 04-30-2011, 06:28 PM
Wiki Edits: 326
As long as you know the piston is at TDC on #1, you can put the timing marks anywhere you want to. Put 'em on the bottom if you want.
Old 04-30-2011, 09:43 PM
FastOrange's Avatar
with a stock pointer and stock balancer of a 1993 block, it should be more like 2o'clock.
adjustable timing pointer hbly dx Engine 9 06-14-2008 03:35 PM
checking timing pointer zephyrc Engine 4 06-03-2008 02:31 PM
Timing Pointer Canadian Charlie Engine 9 03-16-2008 03:25 PM
Timing pointer. lindgren_anders Engine 2 09-09-2007 11:48 AM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
