After winter startup - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2006, 08:46 AM
airman_turtle's Avatar
Im planning on getting the SS going again now that the weather is getting better. Unfortunately i did not put any sta-bil in it before the winter. What do i need to do before getting it going again?
My bro mentioned to dump a little gas in the carb and fire it up. Do i need to reprime the oil? I wouldnt think it would get dry like that over the winter, but i just wanna be safe. any other things to inspect before i start cranking it?
on another point, i know this Demon i got on there is complete junk, and i need to get a new basic holley...i had enough with the damn BG last year.
Old 03-13-2006, 10:08 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I would put 4 bottles of carb cleaner in 5 gallons of gas in the tank.
I would prime the oil system. Cranking with the coil wire off is really not a good way to do it. The engine is still turning with dry bearings for a few rounds.
I would change the oil before I drill prime it to make sure the new oil filter is FULL of oil before hitting the go button.
Ya, that is more trouble, but why chance a bearing problem..... that could be expensive and time consuming.
Old 03-13-2006, 02:20 PM
E.T. divided by $ spent= Speed
Unless its some big dollar engine thats made outta gold.I'd dump a little gas in the carb and zing it off.If its only sat a couple months it should be fine.I start my Volvo up now and agian after months sometimes with little more than a jump start(battery froze.....doh!!)
If your really worried about it prime it again squirt some motor oil in the cylinders.
winter rod ckucia General Rodding Tech 20 07-19-2010 09:43 PM
Outdoor Winter Storage syclone477 General Rodding Tech 7 10-31-2005 06:06 AM
Winter Storage - What to Do? 69ChevelleAddict Hotrodders' Lounge 1 09-30-2005 05:44 PM
How are you going to heat your house this winter? CrashFarmer2 Hotrodders' Lounge 29 09-05-2005 06:11 PM
storing a car for the winter and need some ideas novadan Hotrodding Basics 6 11-05-2004 10:03 AM
