Aftermarket bellhousing for 4L60E? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2007, 09:41 AM
Does anyone sell an aftermarket bellhousing for the 96-up 4L60E transmissions for the BOP bolt pattern? I know there's at least one vendor selling a Mopar bellhousing for this trans. Thanks.
Old 02-11-2007, 04:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What vendor has a bell housing to bolt onto a late design 3 piece case 4L60E?
I have not seen an after market bell housing for this trans yet. Seems like an easy item to design and build.
Old 02-11-2007, 05:02 PM
Keisler sells a 4L60E with a Mopar bellhousing, as seen here:
http://www.keislerauto.com/mopar/tra...omatic-4sp.asp
Old 02-12-2007, 04:58 PM
airworld2's Avatar
bop bell housing
seems like a neat bell but gear vendors od unit would be a better fit under most situations. the cost of these units was too much for most people owning hot rods, also 4l60e transmission has alot of failure under horse power over load
airworld2
Old 02-12-2007, 06:06 PM
327NUT's Avatar
You might give "Wilcap Company" in Pismo Beach, Ca. a call, (805)481-7639. They have been around for a long time and make very good equipment. They make all kinds of trans adapters and flywheels. Don't know if they make a bellhousing or not but probably an adapter to go chev to BOP. you can find them on the web....wilcap.com ....and a properly built 700R4/4L60E will perform just fine IF you dont overpower them, everything has its limits. For further on that see the new (April 07) Hot Rod mag article on these transmissions, page 104..........good luck
Ford Big block 4 spd bellhousing bigblocktorino Transmission - Rearend 3 10-05-2006 03:56 AM
TH350 Bellhousing Broken BrandOmatic Transmission - Rearend 6 09-28-2006 09:29 PM
Aftermarket spring cups or let the springs rest on a shim? sizemoremk Engine 3 01-13-2006 02:51 PM
which bellhousing nick62877 Transmission - Rearend 7 06-29-2005 07:02 PM
Lakewood bellhousing shagginwagonvic Engine 6 02-13-2005 04:51 PM
